Install Problem RK3318 Bqeel R1 Pro
  • Hello.
    Sorry for my bad english.
    I am trying to install LibreELEC on a Bqeel R1 Pro with Rockchip RK3318.
    The usual ways to boot to my usb key are not working (LibreELEC app and "reboot update" command).
    So i tried with usb OTG cable connected to my computer, without DC cable connected but i am not able to boot in update mode.
    Once my Android box started with OTG power supply, i use Terminal Emulator Android app to execute "reboot update" with su (root). The box just start normally...
    Any solution please ?
    Thanks a lot,
    Azertix 😁
    Edited 2 times, last by Azertix (April 15, 2020 at 5:56 PM).
  • I moved the thread because you necro-bumped a 3-year old Amlogic thread so any advice on installing for the other Bqeel hardware is not going to be relavent to your Rockchip device.
  • Hello. Finally i could boot an SD card flashed with LE USB-SD Creator.
    But i issued several errors (see picture).
    Next first error, i typed "exit" one time, LE logo apears, "exit" a second time and then i had a kernel panic.
    Finally, screen and command prompt ended frozen.
    Any advice?
    Edited 3 times, last by Azertix (April 15, 2020 at 6:14 PM).
