RPi != Amlogic, you can't use RPi driver for Amlogic device.
![](https://forum.libreelec.tv/core/images/avatars/ed/1274-edfc0e7cffead5eb4f1b961c6bc4768eefc6e22d.webp)
kszaq -
October 28, 2016 at 10:45 PM -
Ok!
Thanks for your fast response.
Is anyone having problems with the m201D and 17.3 or above it runs but is always locking up on me
have tried fresh installs of all of the 17.3 and 17.4 RC build but it just does the same on both of my box's
m201d users: please try 8.1.5a build (it's in 8.1.5 folder). I disabled DVFS driver, this hopefully resolves freezing issue.
Tested today using MXQ S805_V2.0 Board with 512Meg of RAM. Same issues freezes happen from 3-15 Mins. Moving around in Kodi or just leaving it idle. So far the only stable version that does not lock up is 7.0.1.1.
Hey kszaq! Thank you so much for your awesome work with LE. I have an MXQ S805Q_V2.0 box with the SCI S9083C WIFI chip and I was wondering if you've made any progress getting wifi to work on this. I saw one of your posts where you said they haven't responded to your email so I was wondering if you had any updates on that. I was able to track down the chip maker's homepage but I doubt id be able to get something out of them either.
Exactly the same issue here.
Nobody responded to multiple messages sent in multiple ways.
Please try one more thing:
echo hotplug > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
Thanks a lot! Finally it seems to be working now. Could you explain how to make it permanent? The echo hotplug stuff was executed using Putty, but I think it's valid for the current session only. Sorry if it's a stupid question.
You can add it to autostart.sh Autostart.sh - LibreELEC
I will see if I can add it for m201d build only.
OK, I'll try.
Thanks again for your efforts!
Do you need the nohup in the script ? Do you need it running in background ?
Ex.
No, add this single line and you're done. I will add it for m201d in next build.
Thanks will test it out. Thanks for all your work.
Hi Thanks for the release.
I only have one problem, when i try to connect with ssh in putty i get an error.
It says: ''Network error: Connection refused''. So first i thought it must be my network, but when i try with my other streamer running Libreelec 8.1 it works fine... Can you please help?
Is there maybe any option to get the 7.3.3c nand version to flash with twrp? cause i cant find the file.But the SSH solution would be great!
You must enable SSH in kodi settings
Default SSH disabled
I already did that also when i first started up
