4k 60hz not detected using Onkyo TX-SR393
  • When using my Pi4 through an Onkyo TX-SR393 the Pi 4 will not output in 60hz. Only at 30hz.
    The Xbox 1 which is also plugged into the Onkyo will passthrough 60hz but uses YCbCr420 24bit.
    I have the following in my config.txt
    # 4k 60hz Support
    hdmi_enable_4kp60=1
    hdmi_group=1
    hdmi_mode=97
    Interesting enough my TV a TCL 55r625 does allow 60hz, and I can move the HDMI from the TV to the AVR and the AVR will pass the 60hz signal.
    Onkyo supports the following:
    4K (3840×2160p) 50/60 Hz, 4K SMPTE (4096×2160p) 50/60 Hz : RGB/
    YCbCr4:4:4 (8 bit), YCbCr4:2:2 (12 bit), YCbCr4:2:0 (8/10/12 bit)
    TCL supports the following and I have the HDMI Input set for 2.0
    TCL 6 Series/R625 2019 Review (55R625, 65R625) - RTINGS.com
    4k @ 60 Hz : Yes
    4k @ 60 Hz @ 4:4:4 : Yes
    Using TVService mode 97 is missing when plugged into the Onkyo but shows when plugged into the TCL.
    Is there a way to hardcode the resolution I want?
