Audio offset increment
  • Hi all,
    hopefully an easy one to answer... is there a way to adjust the audio offset increment when playing back videos to a smaller value than 25ms? I can't seem to find the sweet spot with these increments. It's either slightly behind or slightly ahead. I did some research and it appeared I should be amending so settings under ~/.kodi/guisettings.xml called audiodelay or something similar but i tweaked a value in there of 0.125 to 0.025 and it made no difference so i changed it back.
    Basically what xml value affects the increments made in the gui for audio delay (currently defaulting to 25ms). I'd like to reduce this to 5ms to give more granularity.
    thanks
    Ad.
