H96 MAX 4K Decoding / Amlogic S912 8 Core DLP Projector: E: Cannot load volume /misc
  • Hello all,
    I'm having issue with this DLP projector.
    This projector run Android 6.0. I accidentally install a wrong firmware, but then I wipe the data / factory rerest.
    After I installed a correct firmware update from my vendor -, aml_s905x_6.0_H96Max_mac_20190929 - after the update, it went to the " smart projector" screen, then turn black.
    Went back to the recover mode, and when I did the wipe the data/factory reset, at the bottom it said "E:cannot load volume/misc"
    Now I have no idea how to set it back. I need help!!!
    CPU: Amlogic S912 Octa-core Cortex-A53 CPU up to 1.5GHz
    • GPU: Mali-T820MP3 GPU up to 750MHz
    • RAM: 2GB
    • ROM: 16GB
