Display Morelibreelec_usb-sd_creator [LibreELEC]
Have you burnt the image to SD Card using the LE Tool ?
You press the reset switch then plug in power to box whilst holding reset switch until it boots up LE.
Release switch when it boots to LE Splash screen.
Thanks for replying back yes tried it with the Creator but no splash screen ?
