kodi in VM with HD-audio / dolby atmos
  • Hi there
    If been using kodi on windows for a while now. It took me quite some time to have it running with dolby atmos. Now I am planning a new solution and I'd like to run kodi in a VM. I would give it a dedicated GPU and activate GPU pass-through (I planned to use a vSphere). Are there any restrictions? Is it possible to have even HD audio and dolby atmos running within a VM? The machine itself isn't built yet. What should I keep in mind when choosing the hardware?
    Thank you very much in advance for your reply!
    Edited once, last by libreID: No need for an answer anymore. Sorry for bothering you. (August 4, 2019 at 10:58 AM).
  • I just found a more elegant solution. Instead of using kodi in a VM I will use the MrMC app on Apple TV 4K which comes with Dolby Atmos support since March 2019. Sorry for bothering you.
