Hi,
I just switched from a Desktop Linux kodi to a RPi with LiebreELEC. Works good, but the volume of the analog port on Movie playback is very low. Is there a way to adjust this? The RPi volume is on max, but I have to turn my receiver at nearly double the level as with my old system.
Before that I used the RPi with a stock raspbian-jessie-lite and musicbox0.6. And as I remember there was at the beginning some similar problem, but I can’t remember how I solved it. Maybe I switched something with ALSA, but this is not used in libre?
thanks
Tony
