I have an Intel PC/HTPC which has two drives, the first is a small SSD and the second is a rotating 1 TB drive. All of my media is on the second drive. I have tried installing Libreelec using the USB default method. The rotating harddrive is setup as a read-only location. It needs to be read/write. Also the default library locations are located on the limited space SSD. How can I change their location?
