Upgrading from 9.0.2 to 9.2: Problem with VSFTP plugin
  • Hello there,
    Been running LibreElec on a RPI 3B+ for a while. Saw a new beta was out, and installed it manually (downloading the file from here: libreelec-rpi2.arm-9.1.001.img.gz), plopping it in the .update folder and rebooting the device.
    Upon rebooting, I was greeted by the "red look" of LibreElec, informing me that the boot had failed. I went looking in the log files and found this:
    2019-04-11 18:28:41.382 T:1937626160  NOTICE: ADDON: vfs.sftp v1.0.1.3 installed
    2019-04-11 18:28:41.382 T:1937626160  NOTICE: ADDON: virtual.network-tools v9.0.104 installed
    (... some more plugins here ...)
    2019-04-11 18:28:41.382 T:1937626160  NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
    2019-04-11 18:28:41.465 T:1937626160   ERROR: Unable to load /storage/.kodi/addons/vfs.sftp/vfs.sftp.so.1.0.1, reason: libcrypto.so.1.0.0: cannot open shared object file: No such file or directory
    After SSH'ing into the system and removing the plugin (by rm -rf on the folder), I could successfully boot. I then tried to reinstall the plugin from the addons menu, which failed, with these messages in log:
    2019-06-30 01:40:25.185 T:1804620672   ERROR: Requested path https://addons.libreelec.tv/9.0/RPi2/arm/vfs.sftp/vfs.sftp-1.0.1.3.zip not found in known repository directories
    2019-06-30 01:40:25.185 T:1804620672   ERROR: CAddonInstallJob[vfs.sftp]: failed to resolve addon install source path
    2019-06-30 01:40:32.950 T:1610793856   ERROR: Requested path https://addons.libreelec.tv/9.0/RPi2/arm/vfs.sftp/vfs.sftp-1.0.1.3.zip not found in known repository directories
    2019-06-30 01:40:32.950 T:1610793856   ERROR: CAddonInstallJob[vfs.sftp]: failed to resolve addon install source path
    2019-06-30 01:41:38.132 T:1816114048   ERROR: Requested path https://addons.libreelec.tv/9.0/RPi2/arm/vfs.sftp/vfs.sftp-1.0.1.1.zip not found in known repository directories
    2019-06-30 01:41:38.132 T:1816114048   ERROR: CAddonInstallJob[vfs.sftp]: failed to resolve addon install source path
    The references to "9.0" in the URL there made me think my repository info was maybe out of date? And surely, after a refresh, only version 1.0.1.1 was an install option, which installed fine and works (now playing some music over SFTP).
    I don't know if this is related to the 9.2 image, but since I'm running a pretty vanilla libreelec (no extra/custom repositories, no funky addons, ...) I thought it would be wise to report anyway. AFAIK the vsftp plugin is an official kodi plugin as well - since SFTP support was removed from Kodi Core recently, I can imagine a lot of people have this installed.
    Full crashlog attached.
