Here's a build with patches from pec and chbmuc: 2016-09-25-devel
Thanks a lot. Fixed wrong aspect ratio on pvr.hts / MiniMXIII2G/16
I patched latest alex's LE version (7.0.2.003) for KI Plus S2/T2 with chbmuc's incorrect aspect ratio fix. I also added kszaq's support for multichannel PCM.  I had serious issue with audio. After adding kszaq's fix it disappears passthrough setting. I fixed it with dirty patch of AML-M8AUDIO.conf.  In my version is additional audio device "ALSA:AML-M8AUDIO,Analog"  supporting all audio formats (also multichannel PCM).  In HDMI device is no sound for multichannel PCM.
I prepared SDcard version LibreELEC-Amlogic.aarch64-KI_Plus-7.0.2.004.img
I changed version to 7.0.2.004 but kernel is still 7.0.2.003.
Then multichannel isn't work over HDMI?
Cec patch include too?
And would be nice add v4l additional dvb drivers, because alex build not support other dvb drivers.
Multichannel PCM is possible only via HDMI. The setting is strange, to be able play multichannel  PCM over HDMI,  you have to set device "ALSA:AML-M8AUDIO,Analog".
I am not able to modify kernel. Only Kodi related fixies. You have to ask alex for new release.
@all Can you please verify whether aspect ratio is handled correctly in the latest dev build: 2016-10-03-devel
I noticed that with chbmuc's PR very high bitrate H.264 playback gets a little bit problematic as the stream is continuously parsed using CPU. That way you are not able to play high bitrate Jellyfish anymore. I modified the patch to perform aspect ratio tracking only if there is no aspect ratio hint in a stream.
@all Can you please verify whether aspect ratio is handled correctly in the latest dev build: 2016-10-03-develI noticed that with chbmuc's PR very high bitrate H.264 playback gets a little bit problematic as the stream is continuously parsed using CPU. That way you are not able to play high bitrate Jellyfish anymore. I modified the patch to perform aspect ratio tracking only if there is no aspect ratio hint in a stream.
DTB need change too?
Or just copy to update + restart
If you're upgrading from any previous dev build, only update + restart.
I already changed the dtb too.
Seems good, everything fine with it.
Jellyfish is ok up to 160mbit
