Hello!
I am using Homebridge on a Raspberry Pi 3+ with LibreELEC. Now I have the problem that I need to disable avahi in libreelec for Homebridge to work. That would be no problem so far, but I would like to send music from my iPhone to Kodi via Airplay. But this only works when avahi is running. Does anyone have any idea how i could solve the problem?
If avahi is disabled and home bridge works fine and I try to activate it afterwards in LibreELEC, the following message appears:
QuoteDisplay MoreFeb 19 21:58:55 LibreELEC 38a7493b6841[329]: avahi-daemon 0.7 starting up.
Feb 19 21:58:55 LibreELEC 38a7493b6841[329]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Feb 19 21:58:55 LibreELEC 38a7493b6841[329]: Loading service file /etc/avahi/services/sftp-ssh.service.
Feb 19 21:58:55 LibreELEC 38a7493b6841[329]: Loading service file /etc/avahi/services/ssh.service.
Feb 19 21:58:55 LibreELEC 38a7493b6841[329]: *** WARNING: Detected another IPv4 mDNS stack running on this host. This makes mDNS unreliable and is thus not recommended. ***
Feb 19 21:58:55 LibreELEC 38a7493b6841[329]: bind() failed: Address in use
Feb 19 21:58:55 LibreELEC 38a7493b6841[329]: Failed to create server: No suitable network protocol available
Feb 19 21:58:55 LibreELEC 38a7493b6841[329]: avahi-daemon 0.7 exiting.
Thanks!
Greets!
