Hello Everyone:
Just installed LibreElec MXq 7.0 (Kodi 16.1) version on my Acemax MXq s805 , Before i flashed my box, I have copied remote.conf from Android system/etc folder and then pasted into LibreElec storage/.config folder. I rebooted my MXq but my remote still doesnt work ..
Can anyone assist me what i am doing wrong ?
Here is my remote.conf
#this file is configuration for each factory remote device
# work_mode 0
oftware mode 1 :hardware mode
# repeat_enable 0 :disable repeat 1 :enable repeat
# factory_code each device has it's unique factory code.
# pattern:custom_code(16bit)+index_code(16bit)
# examble: 0xff000001 = 0xff00(custom cod) 0001 (index)
# release_delay unit:ms.release will report from kernel to user layer after this period of time
# from press or repeat triggered.
# debug_enable 0 :debug disable 1 :debug disable
# SW MODE:
# bit_count how many bits in each frame
# tw_leader_act time window for leader active
# tw_bit0 time window for bit0 time.
# tw_bit1 time window for bit1 time
# tw_repeat_leader time window for repeat leader
# REG
# reg_base_gen set value for PREG_IR_DEC_BASE_GEN
# reg_control set value for PREG_IR_DEC_CONTROL
# reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE
# reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE
# reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE
# reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME
#amlogic NEC remote
factory_code = 0x40400001
work_mode = 0
repeat_enable = 1
repeat_delay = 40
repeat_peroid = 39
release_delay = 121
debug_enable = 1
fn_key_scancode = 0x47
left_key_scancode = 0x10
right_key_scancode = 0x11
up_key_scancode = 0x0b
down_key_scancode = 0x0e
ok_key_scancode = 0x0d
mouse_begin
0 0x10
1 0x11
2 0x0b
3 0x0e
mouse_end
key_begin
0x43 113 #MUTE
0x01 2 #No.1
0x02 3 #No.2
0x03 4 #No.3
0x04 5 #No.4
0x05 6 #No.5
0x06 7 #No.6
0x07 8 #No.7
0x08 9 #No.8
0x09 10 #No.9
0x00 11 #N0.0
0x45 125 #MENU
0x42 1 #BACK/EXIT
0x0d 97 #ENTER/OK
0x10 105 #LEFT
0x0b 103 #UP
0x0e 108 #DOWN
0x11 106 #RIGHT
0x18 115 #VOL+
0x17 114 #VOL-
0x0c 14 #DEL
0x4d 116 #Power
0x1a 102 #home
0x54 200 #setting
0x53 119 #media_pause
0x44 52 #period
0x57 70 #explorer
0x1e 123 #MEDIA_NEXT
0x1f 122 #MEDIA_PREVIOUS
0xf1 140 #F10/factory_test
0x5b 205 #PROG_GREEN/MUSIC
0xb1 202 #PROG_RED/VIDEO
0xb2 204 #PROG_BLUE/APP
0xb3 206 #PROG_YELLOW
key_end
repeat_key_begin
0x43 113 #MUTE
0x01 2 #No.1
0x02 3 #No.2
0x03 4 #No.3
0x04 5 #No.4
0x05 6 #No.5
0x06 7 #No.6
0x07 8 #No.7
0x08 9 #No.8
0x09 10 #No.9
0x00 11 #N0.0
0x45 125 #MENU
0x42 1 #BACK/EXIT
0x0d 97 #ENTER/OK
0x10 105 #LEFT
0x0b 103 #UP
0x0e 108 #DOWN
0x11 106 #RIGHT
0x18 115 #VOL+
0x17 114 #VOL-
0x0c 14 #DEL
0x4d 116 #Power
0x1a 102 #home
0x44 52 #period
0x1e 120 #MEDIA_FAST_FORWARD
0x1f 121 #MEDIA_REWIND
repeat_key_end
