When resuming a stopped movie (x264) with LibreELEC 9 (also on v8.95.3) on Raspberry Pi 3B & 3B+, the video lags (in slightly slow motion) behind the audio for 60 or so seconds before things get into sync. During this time, a slowly-rotating progress indicator is on the screen.
This is happening pretty consistently on two different RPI's. Both LE9's are running on 16GB Class 10 PNY cards (also marked Ultra High Speed 1 - https://www.walmart.com/ip/pny-16gb-prime-microsd-2pk/148199673). PNY does't make the best stuff, but Ithese cards ran without issue on the previous LE (Krypton) release.
I'm not seeing any difference between wired and WiFi connections.
Both LE configurations use a MySQL library database running on a third Pi3.
Anyone have any ideas about why this might be happening?
Kodi log: http://ix.io/1zz4 - The play event is at 16:44:53:539 and in this case, it took pretty close to a minute for the audio and video to sync.
