- Official Post
Switch hyperion on/off
xevipc1 -
December 27, 2018 at 9:47 PM -
Thread is Resolved
Hm I get this
LibreELEC:~ # find / -name "hyperion*" -print
/storage/hyperion
/storage/hyperion/config/hyperion.config.json.example
/storage/hyperion/bin/hyperiond
/storage/hyperion/bin/hyperion-v4l2
/storage/hyperion/bin/hyperion-dispmanx
/storage/hyperion/bin/hyperion-remote.sh
/storage/hyperion/bin/hyperion-v4l2.sh
/storage/hyperion/bin/hyperiond.sh
/storage/logfiles/hyperion.log
/storage/.kodi/addons/plugin.program.hyperion.configurator/hyperion.config.json.temp
/storage/.kodi/addons/service.hyperion/config/hyperion.config.json.sample
/storage/.kodi/addons/service.hyperion/bin/hyperiond
/storage/.kodi/addons/service.hyperion/bin/hyperion-v4l2
/storage/.kodi/addons/service.hyperion/bin/hyperion-dispmanx
/storage/.kodi/addons/service.hyperion/bin/hyperiond.start
/storage/.kodi/addons/service.hyperion/bin/hyperion-remote
/storage/.kodi/userdata/addon_data/service.hyperion/hyperion.config.json
/storage/.config/hyperion.config.json
LibreELEC:~ #
I edited the syntax error, I corrected it. Now seems I get connection refused. See edited last post
Thankss
- Official Post
Hmm I get this, do I miss some params?
LibreELEC:~ # /storage/hyperion/bin/hyperiond.sh
Hyperion Ambilight Deamon (643)
Version : V1.03.4 (brindosch-c750c41/dc6a602-1522918225
Build Time: Apr 5 2018 01:57:25
ERROR: Missing required configuration file. Usage:
hyperiond <options ...> [config.file ...]
LibreELEC:~ #
- Official Post
LibreELEC:~ # /storage/.kodi/addons/service.hyperion/bin/hyperiond.start
LibreELEC:~ # Hyperion Ambilight Deamon (666)
Version : 1c21232
Build Time: Oct 12 2017 09:47:51
INFO: Selected configuration file: /storage/.kodi/userdata/addon_data/service.hy perion/hyperion.config.json
HYPERION INFO: ColorTransform 'default' => [0; 45]
HYPERION INFO: ColorCorrection 'default' => [0; 45]
HYPERION INFO: ColorAdjustment 'default' => [0; 45]
LEDDEVICE INFO: configuration:
"colorOrder" : "rgb",
"name" : "MyHyperionConfig",
"output" : "/dev/null",
"rate" : 1000000,
"type" : "file"
INFO: Creating linear smoothing
HYPERION (CS) INFO: Created linear-smoothing(interval_ms=50;settlingTime_ms=200; updateDelay=0
EFFECTENGINE INFO: 27 effects loaded from directory /storage/.kodi/addons/servic e.hyperion/effects
EFFECTENGINE INFO: Initializing Python interpreter
INFO: Hyperion started and initialised
INFO: Boot sequence 'Rainbow swirl fast' EFFECTENGINE INFO: run effect Rainbow s wirl fast on channel 0
BLACKBORDER INFO: threshold set to 0 (0)
BLACKBORDER INFO: mode:default
started
terminate called after throwing an instance of 'std::runtime_error'
what(): JSONSERVER ERROR: could not bind to port
LibreELEC:~ #
- Official Post
LibreELEC:~ #
Maybe because of this?
Quote
Tried editing script and changing port 22 instead of 80..Please set the port number back to the original value and comment the Python script out by adding # at that line:
Then reboot, and try the command from my last post again. Don't be too quick.
OK, I set back port to 80, edit autostart.sh by adding # and reboot
After reboot I tried /storage/.kodi/addons/service.hyperion/bin/hyperiond.start
Think I got the same.. :_(
LibreELEC:~ # Hyperion Ambilight Deamon (639)
Version : 1c21232
"rate" : 1000000,
"type" : "file"
started
LibreELEC:~ #
Running the ledon.py gets also the same
LibreELEC:~ # cd /storage/hyperion/scripts
LibreELEC:~/hyperion/scripts # python ledon.py
* Trying 127.0.0.1...
* TCP_NODELAY set
* connect to 127.0.0.1 port 80 failed: Connection refused
* Failed to connect to 127.0.0.1 port 80: Connection refused
* Closing connection 0
curl: (7) Failed to connect to 127.0.0.1 port 80: Connection refused
hyperion-remote:
version : V1.03.4 (brindosch-c750c41/dc6a602-1522918225
build time: Apr 5 2018 01:57:05
Connected to localhost:19444
Start effect Rainbow Swirl
- Official Post
Connection refused.. u.u
LibreELEC:~/hyperion/scripts # python /storage/hyperion/scripts/ledon.py
* TCP_NODELAY set
hyperion-remote:
- Official Post
- Official Post
I guess I found the port 80 error. It's inside "ledon.py". One line must be deleted, and it should look like this:
Codeimport subprocess import time subprocess.call('/storage/hyperion/bin/hyperiond.sh /storage/.config/hyperion.config.json </dev/null >/dev/null 2>&1 &', shell=True) time.sleep(2) subprocess.call('/storage/hyperion/bin/hyperion-remote.sh --priority 100 --duration 400 --effect "Rainbow Swirl"', shell=True,)Please edit the file, and try to run it again:
After that edit the "ledoff.py" to avoid the same port 80 error. It should look like this:
Thanks I deleted that line in the script, rebooted and leds remain off.
I run the script
This is what I get
LibreELEC:~ # python /storage/hyperion/scripts/ledon.py
hyperion-remote:
LibreELEC:~ #
Seems no error, but nothing happened, leds remained off :_(
- Official Post
- Official Post
I finally got it! I recall I installed the Hyperion Service manually in LibreElec when I first set up the ISO (see screenshot attached). I disabled there and now it works!!
The python code is right as you suggested, I un-commented the python call in autostart.sh and now hyperion starts automatically after I reboot!!
You are the man, I owe you some beers. Thank you so much!!
- Official Post
That's great, man! Thanx for the symbolic beer.
Please mark this thread as solved.
Just to be curious, do you know what that line we deleted in python code was for? (The one which contained port 80?)
