Thanks all, ok I'll change the module with a new one. Any advise? At the moment I'm using the same of the guide, DS3231 in M version, I've red that SN version would be better. I've seen also DS1307 thas has external quartz.
DS3231 Real Time Clock installation guide for RPi / /LE8
frankvw -
December 17, 2018 at 9:58 AM -
I don't undestand why I see ds1307, mine is ds3231
ds3231 is supported by the ds1307 driver.
ok thanks. I'll take another rtc but with an external battery
Hi, I've bought another rtc and checked the battery voltage, 3,3V and followed again the guide with same results, +2 hour. So I've tried command hwclock -u -w and time now is perfect. I don't understand why but works. Anyway I'd like to know what's happening
If the -u switch makes a difference, my first thought is that the problem would be related to your time zone / DST settings. As mglae points out, "For historical reasons hwclock default to local time. Use hwclock -u -r to use stored UTC time correctly." I'm in South Africa (GMT + 2 and no DST) and I never needed the -u switch. YMMV.
