Play/Pause problem
    When I press PAUSE and after a while PLAY the music:
    1. stops
    2. track goes about 1 second back (rewind) and
    3. music plays again
    so.. one maybe two seconds of every track is being repeated when PAUSE/PLAY pressed
    and It doesn't matter if I set audio output for hdmi, aux or BT,
    It is always the same,
    I play local mp3 files (I also tried wav)
    Is this a bag?
    or any player feature which maybe switched off?
    Is there any option to change in kodi advancedsettings.xml to fix that?
    I'm using LibreELEC 8.2.5 on RPI3 and Kodi 17.6.
    Regards,
    MM
  • Try upgrading to LE 8.90.006 Here
    If you still have issues:
    How to post a log (wiki)
    2. Restart Kodi
    3. Replicate the problem
