In continuation Wetek Play 2 + Libreelec 8.2.5 + Krypton 17.6 – deinterlacing problems
After upgrading the LE 8.2.5 to version LE9 8.90.004, channels 720i and 1080i with hardware acceleration do not work. The picture is frozen.
It's a Sunday morning, we're all still sleepy.
Any news?
After update LE 8.90.005 problem not resolved.
This new logs http://ix.io/1mtd
After the start of playing video or audio, the kodi freezes. Yet logfile
21:42:22.936 T:4088237280 NOTICE: Disabled debug logging due to GUI setting. Level 0.
I hate to be a party pooper, and I also don't know why some devs haven't seen this yet (I'm not a dev myself), but it is recommended to enable debugging, either via the Kodi GUI or via the advancedsettings.xml file. It will give more detailed info which could help in solving the problem.
So: enable the debugging, restart Kodi, reproduce the problem, and send in the new Kodi log file. Thanks.
Ok, thanks
Dear developers! Where feedback? There are a lot of errors in the log, I builded stand for debugging, why no answers?
Are there any developers who are interested in fixing bugs?
I am ready to help test the program.
Ok. Wetek supports this product and recommend it for installation. Why it is impossible to achieve its correct work?
After install LE 8.90.006 situation is better, but after channel switched, picture stopped on 10-15 sec, then starting play, but picture not smooth.
Coreelec works fine! Thanks.
