8.2.3.1 aarch64: WiFi connection failures
    Problems with wifi connection on two different boxes:
    LibreELEC:~ # dmesg | grep wl_
    [ 8.654440@3] wl_create_event_handler(): thread:wl_event_handler:ae6 started
    [ 8.663988@2] wl_event_handler: was terminated
    [ 8.664100@3] wl_destroy_event_handler(): thread:wl_event_handler:ae6 terminated OK
    [ 8.664107@3] dhd_wl_ioctl: returning as busstate=0
    [ 9.667374@3] wl_android_wifi_on in 1
    [ 9.667377@3] wl_android_wifi_on in 2: g_wifi_on=0
    [ 10.735529@1] wl_android_wifi_on: Success
    [ 10.736324@1] wl_create_event_handler(): thread:wl_event_handler:afb started
    [ 10.795447@1] wl_host_event: Invalid ifidx 0 for wl0
    [ 10.797143@1] CFG80211-ERROR) wl_update_wiphybands : error reading vhtmode (-23)
    [ 659.420254@0] wl_event_handler: was terminated
    [ 659.420316@0] wl_destroy_event_handler(): thread:wl_event_handler:afb terminated OK
    [ 659.420324@0] CFGP2P-ERROR) wl_cfgp2p_disable_discovery : do nothing, not initialized
    [ 659.420343@0] CFGP2P-ERROR) wl_cfgp2p_deinit_priv : In
    [ 659.420552@0] wl_android_wifi_off in 1
    [ 659.420557@0] wl_android_wifi_off in 2: g_wifi_on=1, on_failure=1
    [ 659.421034@0] wl_android_wifi_off out
    [ 670.555638@0] wl_android_wifi_on in 1
    [ 670.555643@0] wl_android_wifi_on in 2: g_wifi_on=0
    [ 671.607977@0] wl_android_wifi_on: Success
    [ 671.608880@0] wl_create_event_handler(): thread:wl_event_handler:b85 started
    [ 671.668350@0] wl_host_event: Invalid ifidx 0 for wl0
    [ 671.670882@0] CFG80211-ERROR) wl_update_wiphybands : error reading vhtmode (-23)
    [ 773.507182@0] wl_iw_event: Link UP with BSSID=98:de:d0:xx:xx:xx
    [ 773.507291@2] wl_bss_connect_done succeeded with 98:de:d0:xx:xx:xx
    [ 773.526796@0] wl_bss_connect_done succeeded with 98:de:d0:xx:xx:xx
    LibreELEC:~ #
    Finally connected. Don't know, maybe the router's fault, but other devices (PC, phone) connected without any problems.
    Thank you.
    BR
