How to debug DHCP problems with libreelec
  • Hello,
    I got a RaspberryPi running the libreelec 8.2.5. I would like to have a ethernet wired connection set-up through DHCP. When I connect my raspberry PI ethernet port to my switch I get an APIPA address (169.254.211.13) for the eth0 interface while the wlan0 interface gets its address fine through DHCP. All other ethernet devices connected on the switch get their address normally. The RaspberryPI with libreelec is the only one that got problems. How could I get the DHCP logs? I got a SSH access and looked around but there is no relevant logs in /var/log and dmesg does not return anything useful either. I also didn't found any dhcp related commands.
    Best regards
    Rémy
  • Run "touch /storage/.config/debug_connman" and reboot then the systemd journal will contain debug information. Connman logging is quite verbose but also quite readable. Interesting to see the stack trace in dmesg, although that is probably wireless related more than Ethernet, although technically 80211 standards are not exclusive to wireless.
  • When I look for DHCP problems using a | grep dhcp, I don't get anything. If I look at the eth0 interface here is what I get:
    LibreELEC:~ # journalctl | grep eth0
    Mar 24 16:12:13 LibreELEC kernel: smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:04:35:27
    Mar 24 16:12:14 LibreELEC systemd-udevd[275]: Process '/bin/sh -c 'echo enabled >/sys/class/net/eth0/device/power/wakeup' ' failed with exit code 1.
    Mar 24 16:12:15 LibreELEC connmand[325]: eth0 {create} index 2 type 1 <ETHER>
    Mar 24 16:12:15 LibreELEC connmand[325]: eth0 {update} flags 4098 <DOWN>
    Mar 24 16:12:15 LibreELEC connmand[325]: eth0 {newlink} index 2 address B8:27:EB:04:35:27 mtu 1500
    Mar 24 16:12:15 LibreELEC connmand[325]: eth0 {newlink} index 2 operstate 2 <DOWN>
    Mar 24 16:12:15 LibreELEC connmand[325]: Adding interface eth0 [ ethernet ]
    Mar 24 16:12:15 LibreELEC kernel: smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
    Mar 24 16:12:15 LibreELEC kernel: IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    Mar 24 16:12:15 LibreELEC connmand[325]: eth0 {update} flags 36867 <UP>
    Apr 24 22:48:50 LibreELEC connmand[325]: eth0 {add} route ff00:: gw :: scope 0 <UNIVERSE>
    Apr 24 22:48:50 LibreELEC connmand[325]: eth0 {add} route fe80:: gw :: scope 0 <UNIVERSE>
    Apr 24 22:48:50 LibreELEC kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    Apr 24 22:48:50 LibreELEC connmand[325]: eth0 {update} flags 102467 <UP,RUNNING,LOWER_UP>
    Apr 24 22:48:50 LibreELEC connmand[325]: eth0 {newlink} index 2 address B8:27:EB:04:35:27 mtu 1500
    Apr 24 22:48:50 LibreELEC connmand[325]: eth0 {newlink} index 2 operstate 6 <UP>
    Apr 24 22:48:50 LibreELEC kernel: smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
    Apr 24 22:48:52 LibreELEC avahi-daemon[373]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::ba27:ebff:fe04:3527.
    Apr 24 22:48:52 LibreELEC avahi-daemon[373]: New relevant interface eth0.IPv6 for mDNS.
    Apr 24 22:48:52 LibreELEC avahi-daemon[373]: Registering new address record for fe80::ba27:ebff:fe04:3527 on eth0.*.
    Apr 24 22:49:30 LibreELEC avahi-daemon[373]: Joining mDNS multicast group on interface eth0.IPv4 with address 169.254.212.6.
    Apr 24 22:49:30 LibreELEC avahi-daemon[373]: New relevant interface eth0.IPv4 for mDNS.
    Apr 24 22:49:30 LibreELEC avahi-daemon[373]: Registering new address record for 169.254.212.6 on eth0.IPv4.
    Apr 24 22:49:30 LibreELEC connmand[325]: eth0 {add} address 169.254.212.6/16 label eth0 family 2
    Apr 24 22:49:30 LibreELEC connmand[325]: eth0 {add} route 169.254.0.0 gw 0.0.0.0 scope 253 <LINK>
    I've added the complete logs in attachment. I really don't understand where the problem could come from. I have 0 information about DHCP and I don't have any commands to retry it. What are the systemd commands that control the emission of DHCP requests?
