LibreELEC 9.0 / Kodi 18.X for Minix X8,X8H,X8H+
datrh -
April 5, 2018 at 9:50 PM -
will patch this next build
its working
Many thanks
After some tests (with whitelist) seems I have a stable and usable kodi 18 (like 17.6 was).
Could you easly put in future releases 'power menu' --> 'Reboot from internal' like 17.6? I would like having stable version in internal and testing in SD and not to have to phisically go to minix to swhitch between them.
I finished trying all of the dtb files and they all produce the same result: the device stays on the android-minix boot logo
I contacted minix and asked for the latest firmware img for the minix 8 and they sent me it:
I don't know if that helps or not but I thought that it might be useful
EDIT: I managed to dump some dtb files from the image. Again, I don't know if it helps but if it does than I can put a download link to them
used the link and installed it, didnt know there was a update. i used the burning tool to get it installed. i might install "libreELEC later.
17.6 was a Balbes150 fork.
8.9.xx is a "true" LibreELEC fork.
With 8.9.xx i had to mod the bootloader script(to be able to install2internal), i need to patch the lan (to fix ip issue).
i don't know if it will still be possible to easily implement "reboot form internal" via a simple diff from Balbes works
if i'm not wrong , Kodi 18 will be our latest usable kodi version on s802/812. Maybe LE team can confirm it?
hey, maybe this is stupid question... but can i install docker ?? I cant see repository...
Bartek
the linux (3.10) that we use for s802/s812 is too old .
check docker on Amlogic builds
thanks for answer soooo.... I must choose between docker and kodi 18 (i need for hbo go ) ?
thx
Bartek
Hi. I need some help I followed the steps in post 1 and it boots from USB but when using Putty it will not installtointernal Error Permission Denied over and over any suggestion?. Iam running on Minix X8H Thanks!
dunno why but on last images some execute (x) permissions are missing.
i will fix that.
I can confirm installtointernal is OK and non-dhcp IP is fixed.
Manual ethernet configuration is working and mac doesn't change every reboot. Thanks!!!!
Display Morelogin as: root [email protected]'s password: ############################################## # LibreELEC # # https://libreelec.tv # ############################################## LibreELEC (community): devel-20181013182917-197066a (X8-X8H.arm) LibreELEC:~ # ifconfig eth0 Link encap:Ethernet HWaddr 10:00:00:2B:FC:3A inet addr:192.168.1.13 Bcast:192.168.1.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:8645 errors:0 dropped:0 overruns:0 frame:0 TX packets:8537 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:2296842 (2.1 MiB) TX bytes:788571 (770.0 KiB) Interrupt:40 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:4 errors:0 dropped:0 overruns:0 frame:0 TX packets:4 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:352 (352.0 B) TX bytes:352 (352.0 B) wlan0 Link encap:Ethernet HWaddr 6C:FA:A7:4A:4C:F7 inet6 addr: fe80::6efa:a7ff:fe4a:4cf7/64 Scope:Link UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:40 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:16712 (16.3 KiB) LibreELEC:~ # reboot LibreELEC:~ # login as: root [email protected]'s password: ############################################## # LibreELEC # # https://libreelec.tv # ############################################## LibreELEC (community): devel-20181013182917-197066a (X8-X8H.arm) LibreELEC:~ # ifconfig eth0 Link encap:Ethernet HWaddr 10:00:00:2B:FC:3A inet addr:192.168.1.13 Bcast:192.168.1.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:91 errors:0 dropped:0 overruns:0 frame:0 TX packets:149 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:16877 (16.4 KiB) TX bytes:29555 (28.8 KiB) Interrupt:40 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) wlan0 Link encap:Ethernet HWaddr 6C:FA:A7:4A:4C:F7 inet6 addr: fe80::6efa:a7ff:fe4a:4cf7/64 Scope:Link UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:47 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:18091 (17.6 KiB) LibreELEC:~ # installtointernal This script will erase BOOT, SYSTEM, and DATA on your device and install LE that you booted from SD card/USB drive. The script does not have any safeguards! Type "yes" if you know what you are doing or anything else to exit: yes Formatting SYSTEM partition.../dev/system contains a ext4 file system last mounted on /tmp/system on Fri Oct 5 17:56:49 2018 e2fsck 1.43.9 (8-Feb-2018) /dev/system: clean, 11/65536 files, 12955/262144 blocks done. Writing kernel image...done. Copying SYSTEM files...done. Copying remote.conf...cp: can't stat '/flash/remote*.conf': No such file or directory done. Formatting DATA partition...done. Do you want to copy your user data to internal data partition? [Y/n] n All done! Rebooting now... Your system will continue booting from SD/USB until you remove it. LibreELEC:~ # -
Display Morelogin as: root [email protected]'s password: ############################################## # LibreELEC # # https://libreelec.tv # ############################################## LibreELEC (community): devel-20181013182917-197066a (X8-X8H.arm) LibreELEC:~ # ifconfig eth0 Link encap:Ethernet HWaddr 10:00:00:2B:FC:3A inet addr:192.168.1.13 Bcast:192.168.1.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:8645 errors:0 dropped:0 overruns:0 frame:0 TX packets:8537 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:2296842 (2.1 MiB) TX bytes:788571 (770.0 KiB) Interrupt:40 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:4 errors:0 dropped:0 overruns:0 frame:0 TX packets:4 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:352 (352.0 B) TX bytes:352 (352.0 B) wlan0 Link encap:Ethernet HWaddr 6C:FA:A7:4A:4C:F7 inet6 addr: fe80::6efa:a7ff:fe4a:4cf7/64 Scope:Link UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:40 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:16712 (16.3 KiB) LibreELEC:~ # reboot LibreELEC:~ # login as: root [email protected]'s password: ############################################## # LibreELEC # # https://libreelec.tv # ############################################## LibreELEC (community): devel-20181013182917-197066a (X8-X8H.arm) LibreELEC:~ # ifconfig eth0 Link encap:Ethernet HWaddr 10:00:00:2B:FC:3A inet addr:192.168.1.13 Bcast:192.168.1.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:91 errors:0 dropped:0 overruns:0 frame:0 TX packets:149 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:16877 (16.4 KiB) TX bytes:29555 (28.8 KiB) Interrupt:40 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) wlan0 Link encap:Ethernet HWaddr 6C:FA:A7:4A:4C:F7 inet6 addr: fe80::6efa:a7ff:fe4a:4cf7/64 Scope:Link UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:47 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:18091 (17.6 KiB) LibreELEC:~ # installtointernal This script will erase BOOT, SYSTEM, and DATA on your device and install LE that you booted from SD card/USB drive. The script does not have any safeguards! Type "yes" if you know what you are doing or anything else to exit: yes Formatting SYSTEM partition.../dev/system contains a ext4 file system last mounted on /tmp/system on Fri Oct 5 17:56:49 2018 e2fsck 1.43.9 (8-Feb-2018) /dev/system: clean, 11/65536 files, 12955/262144 blocks done. Writing kernel image...done. Copying SYSTEM files...done. Copying remote.conf...cp: can't stat '/flash/remote*.conf': No such file or directory done. Formatting DATA partition...done. Do you want to copy your user data to internal data partition? [Y/n] n All done! Rebooting now... Your system will continue booting from SD/USB until you remove it. LibreELEC:~ #installtointernal doesn't work as expected: if I don't copy my user data there are things not working.
For example kodi add-on repository accessible only if I copy user data so seems normal install without user data miss something.
Strange things appens with restore backup from kodi menu: with this version many things not working from backup of previous version. (pvr epg, modland..)
Have to try restore backup to same version what appen.
Now will try get those things working with a clean install of this version, but with a restored from backup for example modland music addon doesn't work (not working after reinstall too)
Edit:
Now kodi repository unaccessible with clean install and boot from sd. Have to try change sd (64Gb) and test all again.
Edit:
not sure i fully understand. i've test the images: kodi repo, LE repo are available and work like expected. i've install a few addons without any troubles.
# 1 updated
# 1 updated
Tryed another sd clean install: 'Could not connect to repository' with kodi repo and Libreelec repo working. This happen with ethernet connection,
With wifi all is working ok. If I disable wifi and back to ethernet kodi repo seems working, but can't download from some sources. Modland addon too seems can't connect to internet.
Switching back to wifi all starts working again. Note not all internet conneciton is not working with ethernet: I was able to install simple pvr client from libre elec repo.
ok i will check
can you try this one and check if fixe IP is ok and Ethernet is now stable?
