Available on Leia test build, maybe Krypton, as I did not try for that, I am able to change the tempo playback speed while maintaining voice pitch of a video using <ALT> arrow keys (I think that was the key I used). The maximum speed is 1.5x, the minimum is .8x. Is there a parameter than can be changed to reduce the minimum speed?
Thanks for any feedback
