Pretty sure your issue is unrelated and will need it's own thread.
Please explain. My LibreELEC does not detect wifi networks, and that is the title of the thread.
The OP is using a USB adapter, you're not.
All I need to know is how to install the appropriate driver for my wifi (which, by admission, was removed from the installation).
This is not radically off-topic, is it?
Your S905w wifi hardware is built-in, and the required firmware is already included. Your problem is due to something other than firmware (something in your kszaq custom build of causing a kernel panic) and is unrelated to this specific thread about a USB dongle, which you are hijacking.
What do you recommend I do? I was referred to KSZAQ from your site for my particular hardware.
I have have also noted that KSZAQ has retired:
QuoteAnother piece of information that I owe you is that I confirm my permanent departure from LibreELEC development. - KSZAQ
I already told you - start a new thread. Probably best if you post it in the Amlogic section.
