Need help by installing Docker Addon
    i installed Docker addon out of the LibreELEC Add-ons. It is now active.
    But when i go into an SSH Session and type
    docker pull dockerfile/java or
    docker run hello-world
    i get the Message
    sh: docker: not found
    What is wrong? Have i forgotten one step?
  • When i go to the Addons, is see that Docker is activated.
    Can i check it on another way?
    For my Understanding: When i install the addon, and its activated, then these commands should work via ssh?!
    Maybe its a Problem with my LibreElec?
  • Which system you are using? RPi2?
    Also check which package version you have installed with command
    ls -al /storage/.kodi/addons/packages/service.system.docker-*.zip
    Then list archive with command
    unzip -l /storage/.kodi/addons/packages/service.system.docker-*.zip
    and check if you have file docker in folder bin. Something like
    11611480  07-15-2017 18:38   service.system.docker/bin/docker
  • yes, i am running an RPi2.
    its Version 8.2.114
    Archive: /storage/.kodi/addons/packages/service.system.docker-8.2.114.zip
    Length Date Time Name
    0 07-15-2017 20:46 service.system.docker/
    0 07-15-2017 20:46 service.system.docker/system.d/
    1059 07-15-2017 20:46 service.system.docker/system.d/service.system.dock er.service
    0 07-15-2017 20:46 service.system.docker/bin/
    1443 07-15-2017 20:46 service.system.docker/bin/docker-config
    1466292 07-15-2017 20:46 service.system.docker/bin/docker-proxy
    27575856 07-15-2017 20:46 service.system.docker/bin/dockerd
    502188 07-15-2017 20:46 service.system.docker/bin/docker-init
    2141732 07-15-2017 20:46 service.system.docker/bin/docker-containerd-shim
    10454160 07-15-2017 20:46 service.system.docker/bin/docker
    6909084 07-15-2017 20:46 service.system.docker/bin/docker-containerd
    36244 07-15-2017 20:46 service.system.docker/bin/ctop
    5025804 07-15-2017 20:46 service.system.docker/bin/docker-runc
    0 07-15-2017 20:46 service.system.docker/config/
    188 07-15-2017 20:46 service.system.docker/config/docker.conf
    0 07-15-2017 20:46 service.system.docker/examples/
    797 07-15-2017 20:46 service.system.docker/examples/transmission.servic e
    791 07-15-2017 20:46 service.system.docker/examples/mysql.service
    639 07-15-2017 20:46 service.system.docker/examples/couchpotato.service
    639 07-15-2017 20:46 service.system.docker/examples/sickbeard.service
    639 07-15-2017 20:46 service.system.docker/examples/sabnzbd.service
    239 07-15-2017 20:46 service.system.docker/examples/var-lib-docker.moun t
    17726 07-15-2017 20:46 service.system.docker/default.py
    0 07-15-2017 20:46 service.system.docker/lib/
    4405 07-15-2017 20:46 service.system.docker/lib/dockermon.py
    2071 07-15-2017 20:46 service.system.docker/addon.xml
    0 07-15-2017 20:46 service.system.docker/resources/
    13041 07-15-2017 20:46 service.system.docker/resources/fanart.png
    0 07-15-2017 20:46 service.system.docker/resources/language/
    0 07-15-2017 20:46 service.system.docker/resources/language/English/
    2205 07-15-2017 20:46 service.system.docker/resources/language/English/s trings.po
    1332 07-15-2017 20:46 service.system.docker/resources/settings.xml
    29284 07-15-2017 20:46 service.system.docker/resources/icon.png
    54187858 33 files
    yes, file docker is in folder bin.
    Ideas?
    Thank you
  • No File?
    What you mean?
    File docker is in there.
    Here is the ssh output.
    LibreELEC (official): 8.2.0.1 (RPi2.arm)
    LibreELEC:~ # ls -al /storage/.kodi/addons/service.system.docker/bin/docker
    -rwxr-xr-x 1 root root 10454160 Jan 12 16:22 /storage/.kodi/addons/s ervice.system.docker/bin/docker
    LibreELEC:~ # ls -al /storage/.config/system.d/service.system.docker.service
    lrwxrwxrwx 1 root root 82 Jan 12 16:22 /storage/.config/system .d/service.system.docker.service -> /storage/.kodi/addons/service.system.docker/ system.d/service.system.docker.service
    LibreELEC:~ #
  • So everything is as it should be. There is no reason why docker binary would not be found.
    Can you check PATH
    echo $PATH
    I have
    LibreELEC:~ # echo $PATH
    /usr/bin:/usr/sbin:/storage/.kodi/addons/script.moonlight/bin:/storage/.kodi/addons/service.system.docker/bin:/storage/.kodi/addons/virtual.network-tools/bin:/storage/.kodi/addons/virtual.system-tools/bin:/storage/downloads/bin
    LibreELEC:~ # docker -v
    Docker version 1.13.1, build 1.13.1
    and you see correct path included (/storage/.kodi/addons/service.system.docker/bin).
  • That`s it, its mssing
    /usr/bin:/usr/sbin:/storage/.kodi/addons/driver.dvb.sundtek-mediatv/bin:/storage/.kodi/addons/service.softcam.oscam/bin:/storage/.kodi/addons/service.tvheadend42/bin:/storage/.kodi/addons/tools.unrar/bin:/storage/.kodi/addons/virtual.system-tools/bin:/storage/java/jre1.6.0_45/bin
    LibreELEC:~ #
    How can i fix this?
