If i try to use VDR for live TV on a Mecool Ki-PRO, i cannot scan for channels. Both with script.config.vdr addon, and w-scan via SSH.
They cannot communicate properly with the tuner.
If i use the channels.conf file from a mini-MX box used with a cheap USB tuner I can watch TV, but with NO EPG. Resetting epg-channel data does not help either.
Just FYI, I tested an Alexelec build for this box and it works fine, both channel scanning and EPG (but it uses a modified driver, a newer VDR and a different channel-scanning tool).
Looks like a driver - tools used - config problem?
