- Official Post
Nothing leaps out to me as being wrong but I'm no Samba genius. If you use smbclient from the console, what error message is returned?
If i change min server from SMB1 to SMB2 or SMB3 in LE i always get the error:
mount error(95): Operation not supported
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
What command did You use ?
Maybe the mount option sec=ntlm can help
It´s not standard to use a NAS as SMB-client - reading manpage could help
Still no success with that option:
#sudo mount -t cifs //192.168.1.3/videos ~/mnt -o username=xxx,password=xxx,sec=ntlm
i googled a little and found this to be a common problem when changing samba server from SMB1 to more recent versions
not LE's or QNAPS's samba specific ![]()
Wow...
after so many hours it turned out to be this simple!
worked perfectly HiassofT , thanks!
edit: -o vers=3.0 also works!
I want to manually map the shares at the unix level at startup. What file would i put the mount commands in for this to happen?
