Logitech Harmony Touch problem
    I just installed Librelelc on a mini itx pc with i3 and everything seems to be working perfectly except I can not make my harmony touch to work...
    I have an HP usb infrared receiver connected, i created a device on my remote using Microsoft as manufacturer and model KODI which was added without any problem but nothing seems to work... a led lights up on the infrared recever every time I press a button but nothing happens...
    Could it be that my infrared receiver is not recognised by libreelec???
    Any help would be highly appreciated...
    I also can't get the pc to turn on from the keyboard but that's for later... after I have the remote working...
    Thanx
  • You could enable debug logging (in the systems settings) and then check in kodi.log if kodi receives any button events at all. Also you might find some more information for your remote here.
