sorry auto piloted Ubuntu paths
Found it ![]()
HQLI-MMCMS-01:~/.config/system.d # file storage-multimedia.mount
storage-multimedia.mount: ASCII text
Found it ![]()
Some additional debug info. The NAS is (temporary) allowing SMB1 so I can get the mount to work. Interestingly the vers=1.0 must be explicitly mentioned or the mount will fail.
So, when leaving out the vers=1.0 doesn't mean that it will attempt to connect over SMB1 (and others) but simply fails again... strange!
SMB 1.0 is not activated ootb, so its no surprise that you need it
Found it
file is okay
What kind of NAS do you use ?
It is very strange overall ![]()
file is okay
my NAS is a Synology with the latest version of DSM (7.0-41890) running on it.
The strange thing is that I only have this issue on the EL running on x86_64 and not with the LE on my raspberry pi 4 (or 3). They connect by the same means to the same NAS.
that makes really no sense, I have no idea left sorry
No need to apologize ![]()
There are gossips that DSM 7 is not yet free of bugs so maybe??
that's very much possible, but then it would fail for all LE mounts to the NAS. In my case, it only fails for the LE x86_64 version which is strange to say the least ![]()
Yeah I understand but sometimes there are very strange things between 2 specific devices / OS releases... I don't know much how SMB protocol works but I think it's a bit complex. And recently I was facing to a strange issue with LE on RPi serving files to Windows client...
