avl6862 tuner - no signal 114Mhz DVB-C
  • Hallo,
    just bought a Mecool K1 PRO Amlogic S905D DVB-T2 DVB-S2 DVB-C box.
    I installed Libreelec on it. Worked great!
    Tvheadend found nearly all services with the pre-defined muxes "Unitymedia-Germany.
    Only the frequency 114Mhz did not work.
    I tried everything, Amplifier, damper, different cables. No success.
    I also own a Wetek Play and a RP2 with a cheap China-DVB-C-usb-stick. Both have no problems receiving 114mhz at the same cable.. So I think it is not a weak signal.
    I also tried Android 7.1 on the Mecool. Same result. All frequencies are fine except 114Mhz.
    Does anybody know if the Availink AVL6862TA tuner is capable of receiving this frequency ?
    Thanks for your help
  • DVB-C supported frequency range is 47 - 862 MHz. Try to connect 'cheap China-DVB-C-usb-stick' to KI Pro.
    Also you can manually increase/decrease frequency.
