OpenPHT - Plex Home Theater 1.9 FOR S905 S805 S912 WeTek Play 2 and other devices based on LibreELEC 8.2
  • Just tried your full build, reinstalled from scratch. I'm still having the same problems I was having with your original builds which is that my volume control does not work on my Wi-Fi remote. Therefore the only build working for me right now is Eugene's.
    It's disappointing to see that you think Eugene stole your work when really he was just trying to help out. It's a shame that you are not willing to share anymore.
    on the git is version with fixed remote
  • Can you post a link please, I cannot find it. All I see is the one you uploaded seven hours ago. Thanks!
    Minix Neo U1, S905 chipset, 2GB/16GB, Dual Boot Libreelec / Android 5.1 lollipop, Samsung UHS-1 32GB Micro SDHC Memory card
  • Did a fresh install once again with your new file that corrects the volume issue on my Remote. Results are that the volume is corrected, remote works perfectly now. But, upon loading OpenPHT , I get a module load error in red.
    Edited once, last by Brachiator ().
  • For those that would like to see what this Plex Home Theater port looks like, and how to install it, I made a video. And a HUGE thanks to Veisen for creating this port. Awesome media player for such a low powered, inexpensive device.
  • Was trying to test your build on my Minix U9-H (S912) but I get a frozen screen on OpenPHT logo (right when OpenPHT was supposed to boot after LibreELEC booted). Here is the log but I think it has to do with this error:
    ERROR: AML: no rw on /sys/class/ppmgr/ppmgr_3d_mode
    Samba works so I pulled the log but SSH was not enabled before the freeze so can't do much.
    Was using this build:
    OpenPHT-Embedded-S912.arm-8.2-devel-20180406101848-r26548-g3a13cd9.img.gz
    Also tried to update a working 8.2.4 SD by updating it using the tar but the same on reboot.
  • ok this is problem in the new kernel i can try to fix it but i havent got this device it is egl problem problem in resolution
    Edited once, last by veisen ().
  • Is there something I can do to test from my side? Just FYI, I'm connected to a 4K TV.
    Edited once, last by zonly1 ().
    can you try this 4k fix for me please
    OpenPHT-Embedded-S912.arm-8.2-devel-20180408042149-r26548-g3a13cd9------4KFIX.tar
    now it is checking resolution like this
    11:45:19 T:4117694160 NOTICE: InitWindowSystem: Using EGL Implementation: amlogic
    11:45:19 T:4117694160 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
    11:45:19 T:4117694160 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940060 Hz
    11:45:19 T:4117694160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 60.000000 Hz
    11:45:19 T:4117694160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 59.940060 Hz
    11:45:19 T:4117694160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
    11:45:19 T:4117694160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940060 Hz
    11:45:19 T:4117694160 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
    11:45:19 T:4117694160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 50.000000 Hz
    11:45:19 T:4117694160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
    11:45:19 T:4117694160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970030 Hz
    11:45:19 T:4117694160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
    11:45:19 T:4117694160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
    11:45:19 T:4117694160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
    11:45:19 T:4117694160 NOTICE: Found ([email protected]) at 20, setting to RES_DESKTOP at 16
  • im working on it now
    Thanks!
    I just uploaded a pic of the loading screen error.
  • veisen ,
    Works perfectly!
    Many thanks!!!
