[8.1.9] LibreELEC 8.2 for S905/S905X
  • Thanks kszaq and johngalt for your contribution to this build its working very nicely. :)
    Nexbox A95X 1GB Ram 8GB Rom Amlogic S905X
    JVC 55" 4k UHD 3D Smart TV
    JVC 40" 3D Blu-ray Sound bar
    1. touch /storage/.update/.nocompat
    2. Download update image to Update directory.
    3. Place device WP2 device tree in Update directory.
    4. Reboot
    Thanks i did exactly what you said but it's hanging on the LE splash screen.
    Can't ssh also any suggestions?
  • Moonlight users: please try updating to 8.2.106c. Unfortunately all I can do is bump packages, no way to test here.
    Causes box to crash when run . Here's the crash log 4G674 can run it again with debug on if needed
    I am able to pair successfully, I see my list of games but as soon as I click on one, my Odroid C2 reboots.
    Crash log
  • Works perfect including SMB #3,801
    LE7.0.3.012j NAND TX5Pro S905X
    Testing Krypton MiniMX S905 1GB/8GB LE-S905.arm-8.2-8.1.0.img.gz
    Winsat ModelCombo Tuner AVL 6862. S905D 1gb/8gb LE S905.arm-8.2-8.1.3.img.gz
    Testing K1 Pro S905 2GB/16GB LE afl1 Builds.  8.0.2e (2017-07-04). LE-S905.arm-8.2-8.1.0.img.gz
    Sharp Aquos Quatron 70 inch TV for testing. 4 Years old.
  • For people saying SMB is working could you possibly mention what OS your server is running? Thanks.
  • SMB OK On Windows 10;)
    -2re
    8.2 ⇒ NexBox A95X 2/8 GB ⇒ Onkyo TX-NR656 ⇒ SAMSUNG 65"LED/UHD/PQ1300/T2CS
    LG BP50NB40 USB Blu-ray
    My 1TB Drive is plugged into my router and files are shared wirelessly.
    Probably not much use to you but Fing Screenshot.
  • Since getting a Minix U1, I went directly to 8.0.2e which works great. I then went to johngalt's testing version and from there to 8.2 testing. I mention the following in case it is of any value to anyone, I otherwise could not be happier with these builds. I have small group of video files (x265) that can play on 8.0.2e but cannot play on either of the other builds (audio plays, video freezes). I believe this has something to do with the way these files were encoded. The wifi driver for the Minix (and others) can only operate at lower channel numbers for 5ghz wifi but otherwise works great. SMB works great with all three builds and I can connect to OSX, Win 10 and Linux. Rewind on all three builds is problematic, not sure if this has always been the case? If I rewind at any speed, I have to stop and then resume playback as the video freezes but the timeline shows that it is playing.
  • Hello! kszaq and Johngalt 8)
    Thanks for all your work. :)
    I have Libreelec 8.0.2.e and work so good on my "T95N (Mini M8SPro)".
    But now i test "[Testing] LibreELEC 8.2 for S905/S905X" with new "Device trees" and new clean box.
    1. gxl_p212_2g_nand.dtb
    But now i have no "Wifi"
    1. gxl_p212_2g.dtb
    2. gxl_p212_2g_kvim.dtb
    3. gxl_p212_2g_nand.dtb No Wifi
    I dont now what difference are with this 3 .dtb files.
    Any help:?:
  • Thanks for all your work
    Mate that signature is so out of order. Read the rules.
