[8.1.8] LibreELEC 8.2 for S905/S905X
  • kszaq
    it's could be nice if the remote control for ki pro would work without place the remote.conf file,
    besides, everything is excellent, and thank you very much for the wonderful work.
  • it's could be nice if the remote control for ki pro would work without place the remote.conf file
    I already said that it's hardly possible due to no proper remote.conf on Android side. I can't place remote.conf for that one device in a generic build as this would break remote control for others. Once you install LE and place remote.conf in config folder, it stays there forever. I think it's not too hard to do this only once. ;)
  • So far, so good! A milestone on the road to Infinity;)
    -2re
    8.2 ⇒ NexBox A95X 2/8 GB ⇒ Onkyo TX-NR656 ⇒ SAMSUNG 65"LED/UHD/PQ1300/T2CS
    LG BP50NB40 USB Blu-ray
  • Hans Gruber I think the error is related to LE 8.2 Samba bump. I will seek for advice on this from LE devs.
    also using samba, but no issues for me, just upgrading from testing8 to 8.2
    It wouldn't surprise if Windows was at fault ultimately as it can see Samba shares on other devices just fine. I really wish Windows supported NFS as it sounds a lot less troublesome.
  • I really wish Windows supported NFS as it sounds a lot less troublesome.
    You have options:
    1. Windows 10 Enterprise with NFS support
    2. Run 3rd party NFS server
    Best option -> NAS
    Beelink mini mxiii-ii S905X 2/16 Gb / Beelink mini mxiii-ii S905X 2/32 Gb
    Sabrent USB 2.0 Gigabit Ethernet [ASIX AX88178 Chipset]
    Denon AVR X3300 - Samsung FHD TV
    Pioneer SC-LX501 - Sony KD-55xd8505 TV(4k HDR)
  • You have options:
    Best option -> NAS
    Yeah I'd ideally like a NAS like a Synology but my current setup is a Frankenstein's monster of an old Intel NUC and USB drives. I didn't realise W10 Enterprise had a NFS server built-in. I'll have to look into that, thanks. I'm currently just using Home but an upgrade might be possible.
  • Greetings,
    The kernel structure of WP2 is MMallow, not Nougat.
    It may not have been
    Best regards...
  • I have a wetek play to running raybuntu's krypton 64bit kernel 32bit libs.
    How do i upgrade to your build on my WP2?
    I tried to upgrade but i get compatibility error
    1. touch /storage/.update/.nocompat
    2. Download update image to Update directory.
    3. Place device WP2 device tree in Update directory.
    4. Reboot
  • kszaq Thx, the build work perfect, no 4k issue. But this build and John's test8 build work same. I post here my question: 10 bit video, but denon hdmi signal show only 8 bit. It is bug, or why?
    The post was edited 1 time, last by RedCat ().
  • I tried this version and found it very good.
    It can play the 4k HDR movies too without that washed out look that present in all previous 8.x.x versions.
    I've updated from JG's testing version and cannot find any difference.
    RPI3 1GB, MINI MX-G 2GB, Mini M8S II 2GB (7.0-devel-20170430185848-r23797-g7772046), H96 Pro 3GB (8.2), H/K AVR 161S, Philips 55PUS8809/12 4k tv
    pel.hu
  • Hi kszaq ,
    I'd installed the 8.1.0 (with your new gxl_p212_1g_nand.dtb) on my TX3-Pro in NAND and it works perfectly for me.
    I've only seen a mior thing:
    The video resolution 1280x720i is missing in video setup menu and 1920x1080p it there twice (1st and 3rd entry).
