execute shell scripts with LIRC using custom key names
  • Hi everybody,
    I'm trying to get LIRC working in LibreELEC. Actually the standard thing works (controlling Kodi with my universal remote control).
    What I additionally want to do with LIRC (I do the same stuff with LIRC on a x86 PC with Ubuntu) is to call shell-scripts on specific key-events.
    It seems that the LIRC version which comes with LibreELEC is limited to a fix set of keys like KEY_LEFT, KEY_PLAY, ... which are mapped on the corresponding Kodi commands. I'd like to use custom key-names in my .lircrc like KEY_SWITCH_LIGHT. I was able to introduce such key-names and
    irw /run/lirc/lircd-lirc0
    prints
    000000037ff00b99 00 KEY_SWITCH_LIGHT Xbox
    000000037ff00b99 00 KEY_SWITCH_LIGHT_LIRCUP Xbox
    when I press the corresponding button on my remote control. But in the system logs I can see the entry
    Jul 9 20:55:41 OpenELEC lircd_helper: lircd-0.9.4c[495]: Info: Dropping non-standard symbol KEY_SWITCH_LIGHT
    And irexec doesn't execute the command. Does anyone have an idea how I can execute a script with LIRC without triggering a Kodi command (this is done when I use one of the predefined LIRC keys)?
    Many thanks in advance!
  • Got it working finally. Here is a short description what I did (maybe this helps other people who want to execute shell commands with Lirc - even if my approach is a little bit hacky ;-)):
    • enable Lirc in Kodi
    • add to /storage/.config/autostart.sh:
    /usr/bin/irexec -d /storage/.config/lircrc &
    • create /storage/.config/lircrc and add your commands - e.g.:
    begin
      prog = irexec
      button = KEY_HOME
      config = /storage/bin/doSomething.sh
    end
    Be careful: If you are used to define your own Lirc-keys here - this won't work. Use one of the predefined Lirc-key names which you do not need otherwise. See for example xbmc/Lircmap.xml at master · xbmc/xbmc · GitHub for a (maybe not complete) list of possible Lirc-keys.
    • make sure Kodi doesn't react on (for example) the KEY_HOME key - create /storage/.kodi/userdata/Lircmap.xml:
    <lircmap>
           <remote device="devinput">
                   <dummy>KEY_HOME</dummy>
           </remote>
    </lircmap>
