Docooler M9S pro - Internet connection problems
  • Hello,
    First of all, I want to congratulate all the people who take is time to help and develop support for Kodi.
    I am new in this type of devices. I bought a docooler M9S pro, it came with kodi 16 pre-install so impossible to update. I had to unistall and install it from google play to update to 17.3. But after that the video rendering is bad so I search in forums and I think I found the solution in LibreELEC, but whith LibreELEC my wired connection doesn't work, the wi-fi do not appears and bluethoot too.
    There is some specs of the device:
    Android 6.0 OS
    CPU: Amlogic S905X Quad-Core Cortex-A53 2.0GHz
    GPU: Penta-Core Mali-450 600MHz+
    SDRAM: 3GBDDR3; FLASH: 32GBNAND FLASH
    Expanded Storage: Supports SD / SDHC / MMC cards SD Card, up to 32GB
    USB host: 4 High speed USB 2.0, support U DISK and USB HDD
    Card Reader: SD / SDHC / MMC Cards
    HDD File System: FAT16 / FAT32 / NTFS
    Support Subtitle: SRT/SMI/SUB/SSA/IDX+USB
    High Definition video output: SD/HD max.1920x1080 pixel
    LAN Ethernet:10/100M, standard RJ-45
    What I am doing wrong?
    Thanks in advance.
    P.S. - sorry for my english
