Librespot addon
  • I unistalled the plugin, deleted the settings folder, installed again, but i still get the same error.
  • LibreELEC 9.0 running on Raspi3
    Spotify 8.4.82.664 running on android 8.0.0
    librespot-log:
    http://ix.io/1v4h
    With the LE8-system and librespot, spotify sees the new device directly.
    With the LE9-system unfortunately it doesn't... From the log however it seems that librespot is not running, right?
  • I installed Librespot 8.2.111 on LibreELEC 8.2.5 on an RPi3B+. I can connect from my Android phone (Spotify version 8.4.82.664) and start playing, but after a few tracks, it stops. From that point I am unable to reconnect to Librespot from my phone until I reboot LibreELEC.
    I have:
    set wait for network in LibreELEC settings
    left username and password blank
    tried Kodi mode
    LibreELEC log:
    http://ix.io/1vte
    journalctl -u service.librespot:
    I can see it claims that the connection was reset by peer, but I'm not doing anything. I found a related Github issue, but I'm not having this issue with the Volumio plugin which is based on Librespot. I've read a few comments (though I'm not sure they are relevant to this issue) from users who removed PulseAudio to fix Librespot. Is that an option on LibreELEC?
    In summary, a LibreELEC device only behaves as a Spotify Connect client while it is not playing a media.
    Last time I checked, a PS4 behaves the same: it will not play Spotify while a game is played.
    It makes sense when parents and teenagers share such devices ;)
    The addon could be updated to switch this behaviour on or off, but I neither have time or a need for it. Contributions are welcome
    That has never been true. The PS4 Spotify app launched with support for music during games and still has it.
  • XelNika
    Librespot does not exit upon network failure.This is a known bug that no developer was able to fix up to now, see eg Panic does not exit · Issue #226 · librespot-org/librespot · GitHub. One solution is to use a stable network connection.
    If you think pulseaudio is the problem, then use ALSA mode: Librespot for LibreELEC only uses pulseaudio in Kodi mode, to stream to Kodi.
    As for disabling Librespot during Kodi playback, it is an implementation choice: the user of Kodi (me) has precedence over Spotify users (my teenagers). If you value this feature less than I do, feel free to change the corresponding Python code here LibreELEC.tv/ls_player.py at master · LibreELEC/LibreELEC.tv · GitHub
    Coders are welcome!
  • hi,
    Thanks for the add on, it works great on kodi LibreELEC 9.
    Is there a feature that keeps the screen black when the next song is starting?
    That would be very nice because I hear a lot of audiobooks about the addon. :-).
  • hi,
    Try to use ALSA output mode.
  • Hi, thanks for this great add-on, finally I can play Spotify over my RPi 3/Kodi. The only thing is that I can't see artist, title or playing time on the on screen display. I have to look at Spotify on my smartphone to see what I'm playing. The only thing I do see on my Kodi screen is a notification in the upper right corner which DOES display artist and title. So somehow Kodi receives this information whenever a song starts. Is there a way to display this information in the OSD permanently, throughout the entire song? Are there any settings I can tweak?
    This feature is only available with LibreELEC version 9.0, when you set Librespot to use Kodi mode.
  • Thanks!
    Before testing it (I really depend on this addon 8))
    Just making sure - Chromebox is still supported right?
    If you have issues with the preview, then simply revert to the latest release (with update).
  • Hello,
    this addon works great until a few days.
    The issue is:
    On my Smartphone I can start playing a song over Spotify connect on my RPi2 LibreELEC box with addon LibreSpot.
    But while a song is playing and I select another song on my Smartphone the song doesn't start playing in my LibreELEC box. Instead the previous song starts from beginning again.
    I change nothing on my LibreELEC box and nothing on my Smartphone.
    On my Wetek play box with LibreELEC I have the same issue. On both boxes I have installed LibreELEC 9.0.0 and Librespot 114.
    I also already tried the Librespot Version 115 or 144s. It's the same issue.
    Anybody else with this problem here?
    Regards,
    MikeCC
  • I have seen a similar problem yesterday evening for the first time. As a workaround I could add the song to the waiting queue and than move to the next song.
