Librespot addon
  • same here.
    Sometimes the wizard is working and Spotify is playing through librespot but there is no sound.
    If I try to reinstall the addon, the dependency "os.libreelec.tv" is missing. Could this be a problem?
    Edited once, last by effe.rnr ().
  • At first, I was too mad to even find this add-on :D
    But now it works perfectly. Still, I can't really decide whether to use Kodi or just use Raspotify using Raspbian Jessi. I will see how it works in comparison, but until now it looks like they work just the same way.
    There is just one question I have: When using a Google Chromecast, I can use it as it was my exact device, just somewhere else. I can also use Crossfade and all the other settings like on just this device I am using as a remote. Would this be possible too? Or at least the Crossfade feature?
    Anyway: Great plugin :) :cool:
  • Here is a preview of Librespot for LibreELEC 8.2 for RPi2.
    Among others, it provides:
    - version a82af96 from librespot-org
    - shuffle support
    - initial volume as a setting
    Feedback welcome
  • Should it work with Kodi 18? I still got the problem with the playback device (latest millhouse built)
    I will build Librespot for LE9.
    Remind me your configuration.
    Have you tried to run the addon wihout using the wizard?
  • I will build Librespot for LE9.
    my configuration is RPi3 with sound output through HDMI.
    yes I tried "default:CARD=ALSA" and "PI: HDMI", but I get no sound + output device will not be saved. When I close the configuration menu and open it again I have to reenter the output device
  • my configuration is RPi3 with sound output through HDMI.
    Addon settings were broken in LibreELEC pre eb9ae56.
    Addon settings appear broken in Kodi 18: this should be no surprise, as Kodi 18 is still pre-alpha.
    But Librespot otherwise works fine on RPi3 with default settings.
    To fix:
    - make sure you run a recent LE 9 (post eb9ae56)
    - nuke Librespot settings.xml (eg, uninstall Librespot and remove related data, re-install Librespot)
    - if you really need to update settings, edit the Librespot settings.xml manually.
  • Here are updated previews for RPi2:
    - for LE 8.2
    - for LE 9.0
    In LE 9.0, the configuration wizard does not set the output device (you have to set it manually).
    This is a bug that I was not yet able to fix.
  • Hi everyone! I need some help.
    I dont know how to install the addon on Libreelec, in my Raspberry Pi 3. I've been reading the forum, but I dont find the way to do it. So if someone could give me the instructions to do it (Im a beginner), I will apreciate it very much.
    Thanks to everybody, specially to awiouy! Great work!!
    As you are a beginner, I suggest you to remain with stable LibreELEC (LE 8.2) and Librespot (from the LibreELEC repository).
    In LibreELEC, goto Add-ons/Downloads/Services/Librespot.
    Then select Librespot on a Spotify app (on your mobile phone, PC, etc)
  • As you are a beginner, I suggest you to remain with stable LibreELEC (LE 8.2) and Librespot (from the LibreELEC repository).
    I was using an older version of Libreelec. Now is working fine with libreelec 8.2.1 and my IQaudio Pi Dac Plus. It sounds great!!! Thank u very much!
  • with output through Kodi it works very well! With Alsa as output device I didn't get it to work.
    It would be nice, if the artist/song-information would be transfered for artist slideshow. Is this posible?
    At the moment, it looks like that:
    thanks!
  • Hi, awiouy in case you missed my posts, maybe you can answer them:
    Librespot addon
    Interaction between Librespot and Kodi is minimal (artist/track notification, playback in Kodi mode, stop/start Librespot on Kodi playback).
    I have neither the time nor the programming skills to improve this.
    I nevertheless repeat my call for Kodi/Python and Librespot/Rust programmers to improve my addon.
  • ALSA:
    Without special sound device (eg DAC) Librespot should play out of the box. Are you using a special sound device, another sound addon, or modified Kodi audio settings? Have you reinstalled Librespot?
    Interface:
    See above
  • Yes it works out of the box with Kodi as output device. For me it's fine!
    With Alsa it connects but there is no sound. But I will use Kodi as ouput.
    btw: no I have no special sound device (RPi --> HDMI --> Onkyo AVR).
  • Interaction between Librespot and Kodi is minimal (artist/track notification, playback in Kodi mode, stop/start Librespot on Kodi playback).
    Thx for the feedback. I would be fine if sending the pause command would stop playback. But I realise this wouldn't be correct way.
