No or intermittent signal from raspberry pi zero w to smart tv
  • Hey everyone,
    I've been trawling through multiple forums and threads trying to find a solution to a really irritating problem with LibreElec on the Raspberry Pi Zero W.
    Basically I have managed to set up the Raspberry Pi Zero W with LibreElec and had it successfully running on standard HD screens, but when I try to move it to a smart TV there is nothing most of the time and intermittent signal sometimes.
    I have tried 2 separate Pi Zero W boards, 2 seperate power cables, 4 HDMI cables, 2 power supply units, Different memory cards, new installations. 3 standard HD screens (all working), 2 Smart TVs (same problem) and confirmed that LibreElec on the pi 3 works with the smart tv.
    Further to this I have tried editing the config.txt file on windows to include the lines:
    config_hdmi_boost=9
    hdmi_force_hotplug=1
    hdmi_drive=2
    ....but with no effect on the issue.
    Any help or pointers on this would be greatly appreciated.
  • It is from the second the Pi Zero is plugged in. I get the colour block flash on screen and then the display flashes on and off throughout the time the pi is switched on, I haven't gotten to play any videos on it while it's connected to any smart tv.
  • Thanks popcornmix, I'll try that when i borrow a meter later this week. Further to what has been done previously, I have since tried different OSes and still get the same problem on one of the Pis and the other I have since found is just burning out the memory cards and so am returning this one.
