Pi Zero W GPIO IR Remote problem LE 8.0.1
  • Pi Zero W, openelec 8.0.1. IR receiver working fine and irrecord worked fine on 2 attempts. I renamed the file to lircd.conf and it's in storage/.config/lircd.conf . I'm using a white apple remote that I have used successfully with osmc on another RPi3. I have enabled the GPIO setting in libreelec settings, but the remote just doesn't seem to work.
    Any ideas?
    Thx
