Bluetooth audio one-click reconnect?
  • Hello Everyone,
    I have a Wetek Play 2 running the latest LE. With the audio streamed exclusively to a pair of BT headphones.
    Everything works fine. The only small irritation is the requirement to reconnect the BT via the LE settings add-on every time I power up the headphones.
    I've added the LE Settings to my Eminence 2 home screen for easier access, but I was wondering if it might be possible to create keyboard / FLIRC remote shortcuts with which I could toggle the connection to the phones. Perhaps with some sort of action that includes phones' name (DR-BTN200) and address (00:18:09:1E:08:6A).
    Thanks for any advice or help you can offer.
    Thomas
    Edited once, last by Confused (March 26, 2017 at 7:17 PM).
