Hi,
Just began finding out about LE. Have been using OE on Cubox i4Pro for several years (since Cubox was released, and Zotac's before that). Having a strange problem with trying to upgrade from OE 6.95.3...(same results from OE 6.0.1, so I don't know if something else really strange is happening).
I downloaded the .tar file for the update from here and unpacked (in Windows 10) with 7Zip. Took the 4 files for updating (System & Kernal + their MD5's) and put them into my Cubox Updates folder (as I have done for many of the OE upgrades over the years)...Verified the MD5 for the files match their MD5 file values as well as the ones on here...
Upon reboot, it begins the update and does the Kernal okay, when it tries to process the System, it says MD5 size error and rolls back the update and then boots normally into 6.95.3. The update files are properly removed from Updates, and my system is back to "normal" (as 6.95.3).
I've downloaded the tar file several times and every time same results (okay MD5, =.md5 values, size error on System)...
I also tried a clean install on a spare MicroSD card and it failed with errors on boot and never displayed anything beyond the LE logo...(no Kodi logo, no menu, nothing)...it looped back thru the LE logo, and the grayed out LE logo stages of the boot process if that makes any difference.
Replaced my 6.95.3 microsd and everything back to normal...
Anyone have any ideas????
Steve
