[Solved] Wetek hub: Boot problems with latest Marshmallow beta
    I installed the latest Marshmallow beta for the wetek hub. Dual booting from sd-card is supported (boot screen shows message and power button on remote can be used to switch boot device from "nand" to "sdcard") but does not work with booting kszaq's builds from sdcard. I tested both Jarvis and Krypton releases, and get
    "error in mount_flash: mount_common: could not mount /dev/mmcblk0p1"
    The wetek hub release from raybuntu boots fine, on the other hand.
    Edited once, last by mmpp (February 8, 2017 at 6:44 PM).
  • Hello,
    I feel stupid - when creating the new sdcard I forgot to change the device tree. It worked fine with the first beta, but not with the second.
    Everything works fine with the wetek hub device tree.
