Hello,
I installed LE build 009 to my MXQ Pro and it worked great. Then I used the usb burning tool to go back to stock so that I can use kodi with VPN, but that method was really slow when using kodi. I recently tried to boot from sd card and tried installing LE to internal again but I'm having an issue. After I install and try to boot up the screen is blank. I tried to boot to sd card after that and continue to get a black screen. To get kodi back I have to use the usb burning tool to flash stock image, then try to install kodi again. After that I continue to get black screen. Could that stock image be causing the problem that I'm having?
