Transmission won't connect to https [solved]
  • I am running Transmission 2.92 (14714) from lsellens.
    I installed fine, but all of my trackers that require https will not connect.
    I have checked my port forwarding and am connectable.
    If I go to a tracker that uses https I get the error : Could not connect to Tracker.
    If I manually change the announce to just http I am able to connect right away.
    Does anyone know why this would be? Is https connecting disabled and is there a way to enable it?
    thanks.
    Edited once, last by canaan (December 29, 2016 at 6:52 AM).
  • problem seemed to be related to the version of transmission I was running.
    I switched from the install by lsellens to the one by milhouse and that corrected my problems. https is now working.
