[x86-64][hadesdevls Builds] LibreELEC Hades - native Dolby Vision, HDR10+ and 3D
  • Quote from ht2tweak
    Post #1 updated. hadesdevls , LMK if anything else should be added, also w/new users in mind.
    ht2tweak Looks good to me, thanks for keeping it up to date. Just one row in the settings table: Hades doesn't have "Asynchronous Frame Preparation", that one is from CroqueMr's build. The setting that does that job in Hades is "Present frames a frame ahead", which is already on When needed by default, so that row can go or be renamed.
    For new users, two short additions you could paste:
    Installing
    For an easy install from Windows, you can use the installer made for Hades (LibreELEC-Hades-Installer.exe, from the release page, with the .img.gz and .sha256 next to it). Any other image writer like Rufus or balenaEtcher works too with the .img.gz.
    Reporting problems
    Please report problems in the GitHub issues, not to LibreELEC or Kodi. Say which graphics card and TV you have, how they're connected, and what you were playing, and attach a diagnostic report from Settings > LibreELEC > System > Submit Log > Create a diagnostic report.
