WireGuard VPN Manager
  • "Host" is the machine ip that the Wireguard service is running on or the ip address of the vpn provider?
    Read https://github.com/BrodjagaRatnik…via-Custom-Mode
    Endpoint = 193.148.18.82:51820 in the generated wireguard conf file from the provider... becomes Host = 193.148.18.82 without the endpoint :51820
    This example is all you need to connect.
  • v1.5.7 (27-10-2026) — Auto-converter for standard WireGuard configs
    Hi all, New version is out with one major upgrade:
    1. Auto-converter for standard WireGuard configs
    Downloading a `.conf` file from your provider in the standard `[Interface]/[Peer]` layout? It now works straight out of the box. The add-on translates it to the ConnMan format automatically, no manual reformatting needed.
    2. IPv4/IPv6 endpoint splitting
    Endpoint addresses (`193.148.18.82:51820`) are automatically split into `Host` + `WireGuard.EndpointPort`, including IPv6 bracket format (`[addr]:port`).
    3. Defaults only when missing
    `ListenPort = 51820` and `MTU = 1420` are only added when the provider omits them. Explicit values in the config are always preserved.
    4. [provider_wireguard] files stay byte-identical
    Hand-made files and existing ConnMan configs are never modified.
    5. Logging outside Kodi fixed
    NameError in provider logging has been resolved.
    Wiki updates:
    Importing ProtonVPN via Custom Mode
    How-To Importing Custom WireGuard Configuration
    Note: Some providers include IPv6 addresses in Address/DNS. If you want to avoid IPv6 to prevent leaking, remove the `2a...:` parts from those lines manually after import.
    Salute!
    Doemela
  • Read https://github.com/BrodjagaRatnik…via-Custom-Mode
    Thanks, that's what I needed.
    Works well now.
    Also upgraded to v1.5.7 and the auto-converter works nicely.
