RetroELEC (Generic/RPi/XU4) Emulationstation/RetroArch/Kodi
  • ricain
    Possibly, but I don't have an iptv service myself so you'd need to fill me in on what's needed.
    meldrak
    If your SMB server accepts user=nobody,password=nopass then you don't need to configure anything, simply access /auto/smb/server as you would a regular directory. If other authentication is needed, see instructions in /storage/.config/autofs/auto.smb (auto.master is in the same place too).
  • This is superbb! Thanks for this!
    Few questions
    1. Can I use this with an Amlogic S905 or 912 box? Will keep the cost low
    2. What controller is best recommended ? There are some games that needed up down left right + 6 other discrete function buttons in addition to the start / select. Im not much of a current gen gamer and I played these games mostly at arcades, hence pardon my unfamiliarity with game controllers.
    3. How does one figure out which button is which is using a keyboard to navigate these games?
    4. If I wanted to create an arcade game type kiosk (which would be so damn COOL!) how do I interface the generic joystick and buttons with the LE box?
    5. There are some games that worked best in portrait mode. Is this setting possible?
  • 1. No.
    2. If I'm not using arcade sticks, then I'm using a Dualshock 4.
    3. I couldn't quite understand your question.
    4. You mean like this? Depends on the interface you connect them with. I'm using USB encoders, which makes them appear as regular joysticks.
    5. Games in portrait mode? Sorry, didn't understand this question either.
  • 3. I couldn't quite understand your question.
    3. I meant that until I get myself a game controller I'm using a regular pc keyboard to play these games but I aint got a clue which key is what button in the various menu pages and during gameplay. Also, I dont even know how to 'shutdown' the box.
    4. Yes, I meant exactly that. Thanks.
    5. Please see the game screenshot attached below. It would be best played with a screen oriented vertically. Is it possible to rotate the image to do that, thats what I meant.
  • The rpi version in the root of your downloads folder is 0 bytes.
    There is another in the kodi folder. Whats the difference? Used that to boot a RPi 3 and its stuck on the kodi splash screen.
  • extremeaudio
    Looks like my storage ran out when uploading. As for your problem, hard to say without a log. I've uploaded some newly built images.
    - Updated XU4 kernel to 5.0.21, RPi to 5.2.5 and Generic to 5.3-rc3
    - Glibc 2.30 (has new ARM performance optimizations)
    - Updated Kodi to latest Leia git
    - Pulseaudio 12.99.2
    - Mesa 19.1.4
    - mupen64plus-next (XU4 version compiled for GLESv3)
    - vice-libretro latest git has lots of improvements (also added the preliminary savestate PR)
    - RetroArch and some other cores got bumped
    - Compiled with GCC 9.2
  • Thanks for sharing new images.
    I tried the Kodi image (RetroELEC-RPi2.arm-9.1-devel-20190808003418-818ab9e.img.gz) on my RPi3b.
    It boots into an empty Kodi screen (just a background image).
    dmesg shows a crash.
    The attached logs are from all USB-devices disconnected, just HDMI and Ethernet connected.
    log-2019-08-17-13.12.23.zip
    Also tried the non-Kodi image (RetroELEC-RPi2.arm-9.1-devel-20190807233002-818ab9e.img.gz), and that looks to boot fine.
    From this thread I tried the 'LibreELEC-RPi2.arm-9.1-Milhouse-20190415220250-#0415-gbcf6a8e.tar' build, which also boots fine into Kodi.
    Tronsmart Ara X5 plus fried by lightning
    RPi3
    (removed from the dust with LibreELEC 8.0.1 still working)
