Can't get GPIO IR Remote Working on RPi3
  • YES!!! I Solved it.
    After doing a factory reset on my TV it started to work.
    Then, when I did all my general settings on the TV it stopped working.
    So I decided to do all settings step by step and it turns out that when I set my TV's "ENEGERY SAVING" to HIGH (because I don't want it too bright in my bedroom) then it disables the IR on my RPi.
    Probably because it's gaining noise on HDMI? I don't know.
    Anyway, I'm glad I solved this. Thanks for all reactions.
    BiTRiP
    Edited once, last by BiTRiP (July 10, 2016 at 5:52 PM).
