Libreelec12.2 has a problem with audioout
  • I've been using Libreelec9.x on a Raspi3. I installed a Hifiberry for audio output. Everything worked great.
    Now I've updated to Libreelec12.2 (complete reinstallation and also reconfiguration of the system). In config.txt, I entered dtoverlay=hifiberry-dac, as it was before.
    After selecting it in the GUI, everything worked as it should. But after a shutdown or restart, the audio output is set to DEFAULT and I have to manually select the Hifiberry again in the GUI.
    What could be the reason for this and how can I make my desired audio output the DEFAULT?
    I have set up Aeon NOX - Silvo as my skin.
    Thank you very much for your help.
    Harald
