Wifi Adapter that Works for Raspberry Pi 4 LibreELEC 12.0.2
  • Hi all, just wanted to post here because of a solution I found for an issue I was having. I'm currently running libreELEC 12.0.2 off an RPI 4 wirelessly (because running an ethernet cable to the rpi is not possible) and I kept having the error "invalid key" which I found through searching the forums was the wifi dropping out. I tried moving my router closer with little success and it became a constant problem whenever I was watching anything. This is partly due to the RPI 4 having kind of iffy wireless to begin with and I have it an Argon case which only worsens the signal. Anyway, I saw that there is not a whitelist for adapters that work with LibreELEC, but I did a lot of googling and found this site that has a whitelist of adapters for linux: https://github.com/morrownr/USB-WiFi and found one that linux 6.6.71 (the base of the current libreELEC distro) would support, which was this: https://www.aliexpress.us/item/3256807258105481.html. My wifi speed went from 60 mbps to 260 mbps (which is close to what I pay for honestly) and it only cost me $18. Anyway, I saw this issue mentioned a few times in the forums so hopefully someone finds this helpful.
