Hi !
I'm trying to use a HifiBerry AMP2 with a Nintendo Switch trough a Rapsberry Pi 4 that's working on LibreElec.
I followed this topic, and I got my computer and smartphone to connect via bluetooth to LibreElec.
Thread
LibreELEC Kodi as a BLuetooth audio receiver??
I can connected my Raspberry Pi 3B+ to bluetooth devices like a keyboard, Harmony Smart Hub remote, and my Android Smartphone. But I have not figured out how to get my smartphone to play music and have the RP3B+ receive that and send it to the speaker system I have connected to the RP3B+ via 3.5mm audio out jack.
Is that possible and if so, how do I configure it?
jfabernathy
But, when I try to connect my Nintendo Switch, it doesn't appears in the Bluetooth menu in the LibreElec settings.
I tried to add it by the CLI, with several commands
I got to see the LibreElec device onto the Switch but in the end I also got an error :
[CHG] Device xxx Connected: yes
[CHG] Device xxx Connected: no
[bluetooth]# connect xxx
Attempting to connect to xxx
Failed to connect: org.bluez.Error.Failed br-connection-refused
Any advice to make it work ?
Thanks for your help and the good work on LibreElec ![]()
